B17 motor!! Clutch????
Hey guys. I’m getting a B17 swap. I have been told the 90-91 integra clutch won’t work, is this true? I have the ClutchMasters Stage 3 clutch kit and Flywheel. Do i have to get the 92-93 clutch, the flywheel will work though,right? thanks fellas!!!:shrug: :shrug: :shrug:
flywheel will work just fine. you will need to get at least a new clutch disk. the pressure plates are interchangable, but the disks aren’t. But typically if you’re replacing the disk you might as well replace the pressure plate as well.
another alternative would be to sell the gsr ys1 tranny that comes with the swap and instead buy yourself a vtec s1, y1, or j1 tranny. That way you wouldn’t have to spend any extra $$ (a vtec s1, y1 or j1 will run about the same price, maybe less than what you can get for your gsr ys1).
