my runs a little bit better when the §§§§§ is advanced all the way if i put the §§§§§ normal in the middle , car will just bogg and die out … i changed the 02 sensor and tps sensor thinking it was that … CEL is on and vtec does engage but i can give it 100% throttle and the car does not go anywhere it has no power wat so ever even in the highway ill step on it in 3rd gear and the car will sound like its moving but not gaining speed please help me out
Read the CEL code and go from there.
will post up CEL codes later on this afternoon
CEL is electrical load detector and knock sensor …???
knock sensor will trigger limp mode which might make it fell really slugish, but I didnt think it will go into vtec if its on.
lets clarify, when you say it sounds like its moving but not gaining any speed. are your rpms increasing, but your speed is NOT?
if i go up hill i need to be in first bcuz if the cars in second it wont have power to make it up , and if im driving regular 35mph in 3rd anf give it 100% throttle the car will not move anywhere feels like a sohc non vtec with 350k
