[QUOTE=Colin;2108814]Please explain your viewpoint. I personally don’t see any reason (performance oriented) why he would prefer the longer geared trans.
I used a gsr ys1 with my b18a for years, it’s a blast to drive, MUCH more fun than the stock long geared trans.
In regard to fitment, the others are correct, just make sure you use the correct clutch disk for your transmission.[/QUOTE]
YES! the only thing I miss about my Y1 is fuel economy. Other then that, my YS1 is great. Even when I had my stock B18B.
The biggest mistake people make with LS motors, the belief that we don’t have top end or can’t have it.
With proper setup, building the head, you can optain incredible results. LS motors have a huge growth capability.
I never noticed a drop in mileage due to my shorter geared trans, still got 25-27 city and 28-30 highway same as before my swap. The gas mileage thing is really all over the map and I think it depends a lot on driving style.
mileage is almost solely a result of driving style.
my mom can pull 30+ out of her car, i borrowed it for a few weeks while i was having work done on my last car and could not even get 25mpg
old lady, highway driving, slushbox-mode auto trans vs. lead-foot me, stop and go traffic, tiptronic-mode…
I would have to agree with the above posters. My mileage didnt drop significantly at all with my short geared trans. In fact (and maybe someone else noticed this) in the city my mileage probably increased a small bit because of how I could drive the car…
You see, with a 5th gear that is so short, I can do 50 or 60km/h easily in 5th thereby keeping the rpms low and using less fuel. Its almost liking have a “D” gear on a manual trans. You just get the car moving, put in in 5th and drive around. Also 2nd gear now becomes useful in stop-and-go traffic. You can come to an almost complete stop without having to shift into first.
Downsides? you have to shift more often in low speed traffic, and at highway speeds you will have to go slower to maintain the same gas mileage. Alternatively if you like to go fast on the highway the car can be pretty loud living at those higher rpm’s.
Upsides? car accelerates faster, is more fun to drive and you can use 5th in the city a lot more.
I would recommend the short geared trans to anyone who wants a little more out of their b18. Its a blast!
[QUOTE=OMG Its Weasel;2109276]mileage is almost solely a result of driving style.
My gs-r’s avg 26-30mpg (about 280 a tank before feed me light) when i drive like everyone else on the road and keep it around 60-65 on the highways…
If you drive on the highway a lot and exceed 75 (as I normally do) it will drop signifigantly.
On the plus side though your motor is bigger you aren’t rockin ridiculous vtec cams that you can watch the fuel go down as you use em… LOL
I love the short gear. 2nd as stated is perfect for everyhting save a dead crawl.
Just make sure you do your linkage up and get everything nice and tight because with all the shifting you will be doing you can hurt the tranny pretty quick (esp. if you have a lead foot :run: like me hehe).
haha wow, thanks for all the replies, very helpful haha.
im looking into getting one, or possibly a b16, any advice on a hydro conversion?
is it hard, or worth it? or should i just stick to cable, also, how much would the hydro conversion cost over the cable??
and btw im selling crower 403 ls cams if you know anyone who is interested, thatd be very helpful. im selling the cams to help buy a new tranny. or if you know anyone selling a b16/b17/ even b18a1 transmission let me know.
Quote:
Originally Posted by turboda4dr View Post
but short gear on a none v-tec motor seem like a waste
Quote:
Because the shorter gears are meant for higher reving engines i.e. V-tecs
Having it on a none v-tec motor is a waste although it is fun to drive i would say, but in essence the whole idea is pointless; just stick with your orignal tranny and call it a day.
[QUOTE=TRiVDA9;2120343]Because the shorter gears are meant for higher reving engines i.e. V-tecs
Having it on a none v-tec motor is a waste although it is fun to drive i would say, but in essence the whole idea is pointless; just stick with your orignal tranny and call it a day.[/QUOTE]
Your logic makes no sense. Just because the vtec motors were made with a shorter geared transmission does not mean that you cannot benefit from a short geared trans on an LS motor. The GSR was the sporty version of our car, the other models were more basic and not so sporty. The gearing paired with the LS motor was chosen to be a good all around gearing. A compromise between performance, gas mileage, and how well it would pair with the average, non-sporty, driver.
Shorter gears are not meant for higher revving engines, you can run any gearing you want on any engine. The gearing you want is going to be dependent on many factors, not just redline. In the case of the vtec engines the gearing is not shorter because the engine revs higher. It’s shorter because in that form it’s more sporty, but more importantly it’s shorter because if you do not have that short gearing you will drop out of vtec when shifting at redline. In order to fully take advantage of vtec you need the short gearing.
I can understand that some may not like it that way but I don’t see at all how it’s “a waste”. It’s a benefit in almost all respects from a performance standpoint.
Drive an integra with a short geared trans before you call it a waste…My bet is you won’t. I personally consider it to be about the best upgrade I ever did to my GS…Well either that or installing my mint DC shift linkage but really the two go hand in hand.
