[QUOTE=buymysoul;2155570]As is evident in my posts above, I don’t know a lot about this stuff. Thanks for chiming in. I’ll get in touch with RS Machine and see what kind of deal they can get me on those OEM pistons with a coating applied.
I’m not sure if I mentioned it in that post, but this same guy said that on average, the cranks they spin up are out of balance by 2 grams and the worst one he had ever seen was 6 grams.
Is this a lot?
Since the only thing that shop will be doing is honing my cylinders, surfacing my block and possibly polishing my crank, I’m not really worried about them (even if the guy on the phone was kind of a douche). I know that their equipment is newer than the machine shop I know of in Bloomington, and I’ve worked a mill before so I know that it isn’t that difficult to put a good surface on something as long as the mill is actually installed properly and truly flat. Plus, if it is computer controlled, it is going to be very hard to fuck up. By contrast, the machine shop by my house has WWII era equipment. I’m sure those old codgers know what they are doing, but I don’t trust their equipment.
At 8500 RPMS, I think what happens is the same stuff that happens at 7500 rpm. Except faster.
I know that an imbalance can cause a wobble and lead to premature wear to my bearings but I also know how to check for that kind of wear while I’m disassembling the engine. That vibration is also energy that is just wasted in extraneous movement and heat. But, while the final build may actually make power up to 8200 rpm, I will rarely spool it up that much. I’m just not that guy anymore. I won’t be doing any quarter mile runs and if I do any racing, it is just going to be some SOLO I auto-xing once a month. I will be weighing the old piston/rod/ring combos and the new piston/rod/ring combos to see if there is any significant difference in weight between the two sets. If there is, I will certainly revisit the idea of getting the assembly balanced; but for my needs/goals I just think the money can be better spent elsewhere.
I think there is a fine line to walk when doing any build as to where do you draw the line. I could certainly save some money in a lot of areas like using ACL instead of OEM bearings, not getting the block surfaced or honed professionally and taking out the crank or messing with the main bearings at all or in general just checking clearances and only replacing with new parts when necessary.
I’m not 100% convinced either way about the crank though. Do you have some kind of evidence or multiple anecdotes about VTEC Honda engines having issues or bearing failure as a result of reving up to 8000 rpms on a stock crank with replacement stock pistons? The only convincing argument with ‘evidence’ I’ve heard is from a guy who has balanced lots of Honda cranks and come to the conclusion that it is typically unnecessary based on what he has seen. I mean, he did say he would be happy to do it, but that he felt the Honda cranks were good enough as is…[/QUOTE]
He’s wrong. Sorry.
The age of the equipment shouldn’t matter if they are maintained well, and the guy running it knows what he’s doing. I’d take old equipment that’s helped produced 1500whp drag cars over new equipment any day of the week. You need to do some more research and actually read through articles on team integra for example and learn about honda rotating assy. They are top notch of course, but it’s baffling to me that’d you’d choose to save money by NOT balancing the rotating assy.
If VTEC honda engines had issues reving above 8k, why does the ITR do so? Why does the S2k do so? ALL honda cranks are forged units capable of reving high. It’s just common knowledge. I dunno where you’re getting your info.
Email Larry. I betcha he tells you to get it balanced. That’s what he told me when I asked him. That’s what every single reliable engine builder both local and national i asked told me to do. That’s just part of building an engine. It’s one of those things that shouldn’t even come into question. Same goes for polishing the crank. Why anyone would not consider it is beyond me.
Good luck with your engine man. I really hope things work out for you.
