SUP GUYS IM LOOKING for a aftermarket throttle body FOR MY B18A1 ALL i can find on ebay is 68mm TB for gsr WILL MY TPS(throttle position sensor)fit ??? HELP ME OUT GUYS WHATS THE BEST TB for my B18A1 that will have a OEM fit direct bolt on???
no one? ANYTHING??
What all is done to your motor? Naturally something bigger than stock will give you more power, but there is such a thing as too big.
Most aftermarket throttlebodies will utilize the oem TPS sensor, but the fire-wall mounted MAP sensor needs to be swapped out for a throttlebody-mounted one, and the stock harness needs to be extended slightly so it will reach.
Learn to type correctly… This BS oF CAPITOL letterz An ISH gets old as FAWK and makes it seem like you are yelling. Neither of which will get people to reply any faster.
Your mom is a bitch thanks for nothing
I answered one of your questions, fuckstick, and informed you of another thing you have to do if you install an updated throttlebody… yet you still act like a 7 year old girl because you can’t type like a grownup. Classy bud, classy.
:fingban::fingban::fingban:
your not going to get any help or be any kind of productive on here if thats how you react to people helping you. you should be banned or something.
and fyi he answered your question very well. when asking about what kind of upgrade you should get it helps a lot to let people know what you already have. putting a bigger throttle body on a stock motor is kind of dumb. you should spend your money else where like on the mavis beacon. its a good investment in the long run.
