Okay, not sure what to do. I could do a swap next march but I really wanna do a build up on my stock motor. Would b20 Cams make much a difference in my car? and aside from taking everything apart to get to them, Is there a certain way I MUST lay these in or can I just match them with the ones that are in there?
Anyone know how much b20 cams will cost me used, or new?
will this even be worth doing?
Lots of questions I know, but with so many options, I w ant somethign fun.
B20 and 94 up LS cams are basically the same from what I understand.
After installing the cams, start the car and run it at about 2000 RPM for 15 minutes or so. Cams dont’ really need to be “broken in” but I always follow this procedure and have never had any problems.
Sounds easy enough, I appreciate all of your guys’ input. Is there an easy way to tell if Someone is trying to “screw” me on these? You know, wear and tear i need to watch for.
