B18A heads
I wanna do an ls/vtec, would it be easier if i found a type r head instead of putting a b16a head on. I know there is a lot more that i would need if i but a b16 on. Would my intake manifold fit the type r head? Fuel rails, etc?
Thanks
i would use teh typeR manifold:clap:
It would not be easier , it would be the same difficulty. A typer head would flow better b/c or the mild port & polish. but would probably cost more. B16 IM would fit on type R head and vice versa. B18 IM would not fit either. I would recommend getting B16 head w/ typer R or Skunk2 IM unless you found a deal. Of course if you’re buying a complet head. The ITR head would also have upgraded valvtrain and cams. (for the added cost)
