B18A, idle issue, fitv/iacv cleaned, no vacuum leaks
I HAVE USED SEARCH AND BEEN THRU ALL THE STEPS ON THOSE THREADS.
FITV cleaned and adjusted all the way in.
IACV cleaned, even switched off another motor to check.
Sprayed all over the motor to check for vacuum leaks, NONE found.
Intake manifold tight.
Idle screw all the way down.
check engine light not on.
I started out with a 4k cold and 3k warm idle. I looked at the information on here and followed the steps to get it down to 2k cold/warm.
When I block the bottom hole in the throttle body going to the FITV its stays at 2k. When I block off the top hole to the IACV it drops to around 1k.This states that the IACV would be bad but i switched it out and still the same.
Anything i missed let me know.
