Originally posted by rcnacura
[B]There is a difference between the two heads and the b18b cams are slightly more agressive. I took some measurements on them because I thought I got screwed on some cams, but they are a “little” different.
And there is no way that the extra 200rpm redline is going to make the added HP. The LS engine aren’t the top end motors like the vtec. I’ve seen dyno’s and the difference is where the 10hp is made.
I’m still somewhat skeptical on the increased redline claim, but who know I don’t work for honda. As daver said it might be fuel mapping. Or what I think, the increased port sizes with the IM, and EM. [/B]
well maybe you got ripped off after all, i have right now in my hand as i speak…sets of cams from bothe the 90 and 93…
hmmmmmmmmmm, did the measureing before,and still same.
looks pretty much the same today…*unless I GOT RIPPED OFF. (which could be posible)
well rightnowi dont care, these are useless now…
y?
ans: :mad: VTEC:mad:
let me tell you something…
Redline is just a single point on a engine’s performance, you will have to look throughout the dyno’s sheet band to understand an engine’s behavior.
If a redline point on one engine is higher than a other (even just by 200rpm), the power difference can be tremendous, because the initial difference in the dyno line can occur at 2000, 3000, or @ any RPM point, and by the time both engine reaches redline…one can be up to 20HP above the other.
both the 90-91 and 92-93 ls ecu’s can be completely different in setting and can create big differences in power, regardless of RPM redline points.
still not conviced?
take a look at the GSR engine…and the celica GTS.
the GTS is rated at 180hp, and the GSR is rated at 170hp
now believe it or not…the GSR is a stronger engine (power wise)and will pull a car down the quarted mile faster than the GTS, even though the GTS has a higher peak HP rating (10hp above the GSR).
the GTS has good power but the real power band is above 6300 RPM, and on the other hand, the GSR has power on the bottom end, and above 6300 RPM.
i am simply saying, numbers and redlines are not enough…a modified turbo VW bug, has a peak 350+hp to the wheel at 3000 RPM<<<…L@@K at how low that rpm level is…that is where us hondas are just gettin started.
yet a turbo GSR will push 350+hp to the wheel @ 8000 RPM…
thus both cars will behave very differently…
here is a link where the SAME engine (H22- prelude VTEC) is mounted with two different ECU’s (GSR’s ecu, and H22’s ecu) and look at the BIG difference in the behavior of the engine under the influence of two different ECU’s.
hope i explained it clearly for u…
later
