B18c swap what tranny?
So what tranny are yall using that have a B18c1 swap? Are u using the G3 hydro trans? or a cable trans? I have my B18a out and I have the option of building the B18a or getting a B18c1 and building that. I found a website that had a motor,tranny,ecu,harness,axles for $2700 from a GSR but i lost the website, it was like honda motors or something. Im gonna boost either one, should I use 9.0-1 or 10.5-1 compression for boost. I saw a video of somone with a B18a 10.5-1 compression and 10 psi and it ran mid 12’s.
I am running a YS1 tranny off of a B17 and love it. the website you are probably talking about its hmotorsonline.com
if you searched you would have found it easily.
so its a 92-93 GSR tranny? I will need to get a different clucth disk then since I have a CM disk for 90-91 teg spline drives. Yes that is the site, THANKS SO MUCH, I went thru my history but didnt see it
aight after looking around on the site, I see I can get a B16 for about $1800 or a B18c for $3100. Both being a complete changeover. Do I need a diferent shift linkage than what is in the car from the B18a? if not the price is cheaper since I can get the motor,tranny,ecu,harness for a B18c for $2750. Is the B16 too small for the DA chassis? I thought I saw a dyno graph somewhere where a B18a and a B16 were dynoed at 10psi and the B18a made alot more torque and about the same amount of hp as the B16. I just really need to decide on what motor im gonna use. Ill use spray for a little till my turbo system is completed
I got my motor for really cheap thats why i got it and thought the B16 was a little small. if power is an issue go with the C1 then. I am using the ys1 tranny because i like the short gearing.
aight, well my motor is out but we havent opened it up yet. More then likely Ill use a B18c, will I need a GSR shift linkage? Ill also problly use a cable trans instead of the hydro unit. I do wanna say thanks you for theinformation u have given me
Use your existing shift linkage!
You’re welcome and good luck!
ok cool, what are u using as a ems? iv been playing around on uberdata but im far from done. when u swaped ur motor did u use the gsr axles or the b18a axles? I guess what im trying to say is will the B18a axles fit the GSR tranny or a B16 tranny? Once again thanks so much
I have a B16a (OBD1) and YS1 w/LSD tranny swapped into my 90 sedan. I used the same axles that ran with the B18 before it died. You should be fine.
I am running a pr3 ECU (the OBD1 version) which is stock. I do not have any experience in non stock ECUs, I am sure there are a ton of people here that can answer that question.
well im thinking of swapping to a B18c so ill use the VTEC ecu chipped with uberdata. Thanks for the info on the axles though
i have a c5 in mine i used a A1 at first cuz swap broke me, D: then got a j1 lsd tranny… imo its too short so i just got an itr lsd tranny and i love it, gears are spaced great and it pulls like hell, its pretty exspensive but i think all around itr tranny is great
You do realize that the 96 spec ITR tranny has the same gear ratios as the J1 right…?
It must have been psychosomatic…
it does? fells leveled out to me compared to the j1… whatever it is it feels great lol
I bet it does. The ITR transmission is STRAIGHT BUTTER. It’s even better when you add ITR shift linkage and shift lever :rockon:
