Before anyone says anything about searching… trust me I did that already, didn’t find what I wanted to hear.
I’ve been a member here for a while, posting here n there, no build thread just yet
Talking about the build, I want “poor mans” ITR swap that’s reliable and has about 220 to 250hp. I will be using this as my daily.
Here is what I have so far:
Head: brand new never used ITR head
[INDENT]ported
polished
shaved
Ferrea 5000 series valves - all seated and installed by my local machine shop
intake valves are oversize - don’t remember the spec
OEM ITR valve seals - not installed yet
Vtec solenoid - used 3rd gen GSR
[/INDENT]
Block: used B18C1, hence “poor mans” ITR
[INDENT]
nothing done to it yet
got everything but pistons, crank, oil pan, rods and studs[/INDENT]
Question is, with the current valve set up what would be good valve springs and cams set up? Can I go with ITR cams and springs for this set up? Or go with something aftermarket?? also OEM or Ferrea valve keepers?
I got the head as a deal, someone ordered 5 of them from a shop…for a track car, then they canceled on the order. So I ended up picking up what has been sitting on the shelf for past 2-3 years.
Also what do I need piston wise?? Would OEM pistons be okay or get something better? High comp or low? APR studs? eagle rods or??
Skunk2 Ultra Series Street manifold will be used.
Just need some help too much stuff to consider and too much to choose from.
I’ll try to assemble it my self, just bought ITR manual… if not then I’ll have to find someone to build it for me.
Thanks guys
