B18C1 into my DB1
What do I need to complete this swap? As in which axles, ecu, etc.
Thanks in advance!
after checking your profile…i see that u have a 1991 DB…the 90-91 integra’s are OBD0 so swaping over the motor is gonna take a little more work. you have the option of switching over your harness to OBD2 but, might be more costly, pending what you know, and who you know. the other option is to convert to OBD1 then get the OBD1 to OBD2 jumper harness, (im not sure is there is such a thing as an OBD0 to OBD2 jumper harness). so pretty much your biggest problem is wiring. there are certain companies that can convert your wires for you like, CHASEBAY or RYWIRE…it’s real pricey, but completely worth it.
things you’re going to need:
*complete motor: distributors, engine wiring harness, axles, LSD transmission or and hyrdo tranny(you can use ur stock tranny but…not suggested)
*OBD2 O2 sensor(2x if you want to run primary and post 02)
*cable to hydro adaptor(if you go with hydro transmission)
those are the main things. you’re definitely going to need more parts, but it depends how professionally you want it done, or if you just wanna ghetto rig it to save you money.
*just keep in mind that there are so many options that you can go with in doing this swap and any other swaps. i ONLY suggest doing it the right way because i live in CALIFORNIA and if it’s not done the right way, don’t do it at all. California Laws are STRICKED AS HELL!!!
Read the guide and search.
http://www.g2ic.com/tegtips/engine/15.html
