k i know i would need a b18c ecu and a wiring harness…is there anything else i would need? cause im planning on just getting the long block and useing my stock transmition
Thanks
Thanks
SEARCH! and READ THE TEG TIPS!!! (more specifically the “Engine Swap Guide”). That will give you all the info you need, and then some! come on back and post questions if you are having trouble working out the small details.
