I need some advice, my next project is going to be dropping a b18c5 into my 1990 gs teg. I want to keep my car an auto (commute a lot every day) and I was wondering if possible, and how easy it would be to install a techtronic trans. out of a prelude, accord? Am I missing a car that has a techtronic trans that would be an easier swap? ![]()
Use the C5 with an auto XSI ECU Get an XSI auto tranny for better performance too. I’ve seen them for $200
Why do you sujest the auto XSI tranny?
What is it’s main advantage over other transmitions?
one more question forget the techtronig trans. what is the best auto trans. that will connect to the c5 and the car?
any sujestions welcome.
thx.
The XSI or B16a auto tranny has shorter gears and a taller final drive ratio than the regular USDM auto trannies giving you better accelleration (sp?).
The best part about it is that they are LSD equipt and they were meant to work with a VTEC engine with it’s higher HP and RPMs.
As for fitting a Techtronic tranny, there isn’t one that will work.
Thank you for all your help.
