B20 block question
I’ve heard people tell me that if you sleeve a B20, it’s better because the walls won’t be as thin as they would be if you sleeve a B18 block; like if your looking for a big bore, such as a 85/86mm+ bore.
Is this true?
i dont really know. but im planning on sleeving my b18 to 85mm.
but i have no idea if a resleeved b20 has thicker walls than a resleeved b18 w/ the same bore.
i also dont know if it would make that much more difference in strength.
but i think the largest bore in a b series is 87mm. not sure tho
good question though
Along the bore centerlines, the thickness is fixed by the bore (bore spacing has to stay the same). Elsewhere, I’m not sure if they are thicker, of if the advantage is that the sleeve is a more durable metal.
if you sleeve a b20 its the same as sleeving a b18a/b so might as well start with the cheaper block
Okay –
But wouldn’t the ‘hole’ for the sleeves be bigger in diameter for a b20 block, and able to handle a wider pair of sleeves? Otherwise, wouldn’t then the walls of the b20 block would be thinner than it’s b18 counterpart in stock form… ?
:shrug:
i believe the overall cylinder diameter (hole) is the same, except the b20’s are bored out more. either way they would need to be cnc’d out for the sleeves to be dropped in.
http://dwolsten.tripod.com/articles/jan96a.html
reprinted from Automotive Engineering, January 1996
Honda’s Siamese-quadruplet cylinder liner casting
“In automobile development, the weight reduction is and always has been a significant and challenging issue. When the weight of the engine itself is to be reduced, the proportion of the weight reduction accounted for by the cylinder block is very large and thus very necessary,” asserts Honda. The company has been vigorously developing and producing engines, many of whose major components are aluminum, particularly cylinder blocks. It adds, “Cast iron sleeves are being used as cylinder liners in more aluminum engines; this is an obstacle to further weight reduction.” Some of the solutions Honda suggests are use of 1) a hyper-eutectic aluminum-silicon alloy (A390), 2) an aluminum liner on which Ni-SiC powdered dispersed plating is applied, and 3) a metal matrix composite, any of which enables the production of a linerless light-alloy cylinder block. At present, its cost is prohibitively high and its manufacturing process too complex for volume-production vehicle models.
So the more-commonly used technology is separate iron liners cast in the aluminum block, which in Honda engines requires at least a 9 mm minimum distance (web) between cylinders. These factors determine an engine’s outer size in proportion to its cubic displacement, and there lies, literally, a rub.
In more practical considerations, Honda was readying its first compact sports utility vehicle, the CR-V, which would be produced, including its aluminum engine, at the company’s Suzuka factory, the home of Civic cars. In fact, the CR-V, though a considerably larger vehicle, belongs to the broad Civic strategy that the company was pursuing, and that would produce more variants and derivatives.
The CR-V, with good off-road capability, would need an engine with about a 2.0-L displacement. Honda’s type F20A engine of the Accord family, with its width of 694 mm, would not fit in the shell, and comes from another factory source. The engine must be of the compact type-B family, for the sporty Civic and Integra cars. The type B16A 1.6-L unit, and the B18B 1.8-L version, shared the same block with with the engine’s overall width of 601 mm. The B18B’s 1834-cc capacity was obtained by stroking the B16A to 89 mm. Further enlargement to a planned 2.0-L capacity could only be achieved by increasing the bore of the B18B, however, the engine’s high-pressure die cast aluminum block with separate iron liners left no room for such enlargement. Thus the development of a new one-piece cast liner unit with four integrally cast cylinder liners came about, which Honda describes as “consecutive liner construction,” or “quad-sequential sleeve block.” It is more like Siamese-quadruplets. With this liner construction, the web distance, or distance between the inner walls of the adjoining cylinders, could be reduced to 6 mm from the separate lines’ 9 mm, while retaining the same bore pitch. This was the essential requirement so that the new block could be cast and machined on the existing Suzuka lines. This enabled the addition of 3 mm to the bore, to 84 mm which, combined with the B18B’s 89 mm stroke, increases the engine’s cubic capacity to 1972 cc. Further, the increase in block mass is only 0.8 kg, from the B18B’s 25.3 kg to 26.1 kg. Efforts were made to shave mass from other internal and external components of the B20B, achieving the end result of a total dry mass of 144.5 kg for the new engine, to the smaller displacement B18B’s 148.1 kg, making it one of the lightest in its displacement category.
There were a number of technical problems that accompanied the new block construction that had to be solved. The main problems and solutions were as follows:
Deterioration in cylinder cooling because of the mono-liner construction–The liner connecting point between two cylinders is the most critical area that may be affected by different temperatures between the two materials, the aluminum block and the cast iron liner (there is no coolant passage in this area). A number of connecting point configurations were investigated at WOT at 6000 rpm. An optimized connecting point configuration with the least temperature rise in the area and in the aluminum portion was selected to ensure adequate cooling capability.
Casting gap that may develop between the iron liner and the aluminum block body during aluminum’s solidification process–With the mono-liner, the direction of molten aluminum’s solidification is different from that of casting-in separate liners. Residual stress exerts inwardly and fairly evenly in the case of separate liners, whereas with the mono-liner unit, its direction is outward along the aluminum casting’s outer periphery, thus causing a separation or gap. Honda’s solution was the casting of “spines,” tiny cylindrical protrusions on the outer surfaces of the critical areas of the liners that ensure secure bonding of the two materials. Honda reports that gap occurrence has been reduced to one percent of what it would be without the spines.
Damaging of the casting and spine by residual stress–The spines receive solidification and contracting forces, thus the area around the liner wall connecting point is subjected to extremely high residual stress, which may damage the spines or crack the aluminum casing. A clamp placed atop each cylinder liner, that provides a path to molten aluminum, disperses concentration of stress, making it similar to that of a separate liner.
Liner distortion due to casting stress–In the mono-liner block casting, contracting force is greater in the X axis (the block’s lengthwise direction), that may deform the cylinder bore shape. The mono-liner unit has calculated, slightly oblong circular shapes that re-form to true circular shapes during cooling. Further, the liner unit’s bottom portion is subjected to higher solidification stress, bcause of larger aluminum mass in the area. The liner is, therefore, initially shaped as a frustum, which re-forms into a right circular cylinder in casting.
A senior Honda engineer says that mono-liner casting techniques had been presented in papers, the oldest by Ford to his knowledge, and some six years ago by Daihatsu; however, one has reached actual product application. Honda has applied for 13 patents comprising 44 items, according to the engineer.
wow xdeep…
So basically for the cost, you might as well stick to ur trusty b18 block, if your looking to re-sleeve.
:bow:
" The B18B’s 1834-cc capacity was obtained by stroking the B16A to 89 mm."
But isnt there something else different here? otherwise we would all run 1.8l vtecs right? Its not as simple as swapping the rods and crank or am i wrong?
depends on deck hight and maximum bore capacities of the motor itself. a b16 can never have as much stroke as a b18, because the block itself is shorter, so even the best stroker kit would never work, because physically, the pistons would hit the crank shaft at bottom dead center. if you sleeve a b18 or b20, it is THE same thing, they share the same block, just the b20 cylinders are bored out 3mm in diameter more than the b18.
so how do you get a b17 then?
b17 is a b16 block with a slightly higher stroke. shorter piston skirts, longer connecting rods, and a bit more stroke on the crank…keep in mind, not much…don.t remember by how much but i thing it’s only 2mm or something like that.
I just find it weird that we just cant swaps cranks to stroke these, Im glad
B20 blocks are cheap, here I come CR-VTEC!
