B20 cams on a 91 B18A1
Are the plug and play??
Can I use the same distributor?
Will they improve any performance??
Thanks…
you will loose 7 hp
its very common to put ls cams in a b20 to boost the hp by 7hp so the other way around you will loose 7hp
if they’re b20z cams, they are identical to a b18b’s. if they’re from a b20b, from a performance standpoint, they are the worst cams available for b series.
needless to say, either way don’t do it
guys thanks a lot!!! I almost buy them…
:pupeyes:
you can but b18b1 cams in youre a1 too
