i’ve got a 96’ b18b shortblock with a 99’ b18b head in my teg right now. would swapping the head for a b20 (non-vtec) be worth it?? why or why not??
the two heads are the same. Maybe the cams “might” be slightly different, but hardly worth the swap effort to find out. leave 'er be
cool, thanks. i guess its just the b20 block that makes a differance then, huh?
huh?
i thought you just had the 98 ls motor, and let me explain b20s, you only need the bottem end if you have a vtec head for it, that will give you awesome compression, the only reason b20s are good is the torque, the bottem end isint that great unless you have the original head or a vtec head.weird thing, but try to put in the b20 as a whole, or just sell me the bottem end:roll:
i have a '96 b18b block w/ a '99 b18b head.
