b20 ppl help which cams gears
hi everyone been searching but couldnt find an answer
well im just swapping in my b20b motor and was wondering should i swap my b18 cam gears or stay with the b20b cam gears thanks a lot
It shouldn’t make any difference. B-series cam gears are all pretty much the same. You do want to swap the LS crank pulley onto it though.
why would you swap stock cam gears :dozing:
Why the crank pulley? What about P/S pump & bracket? I’ll be doing this soon too, & wanna keep A/C & P/S.
:getsome::manual:
Corniest quote ever: “Get yours today! JDM is IN!”
[QUOTE=h93da6;1954095]Why the crank pulley? What about P/S pump & bracket? I’ll be doing this soon too, & wanna keep A/C & P/S.
:getsome::manual:
Corniest quote ever: “Get yours today! JDM is IN!”[/QUOTE]
because the b20 crank pulley is different and you would have to use different size belts on the a/c and p/s. everything from the b18 will bolt onto the b20. go read one of the many b20 threads for details.
Thanks man. /\ /\
I figured as much. Just wanted to verify. I have been doing my research, just didn’t find that answer. Probably should be on B20Vtec.com more.
:getsome::manual:
