b20 question?
i have a b18b engine with crower cams and valve springs. iwas wondering if i get a b20 crv engine can i swap my cam with out putting my valve springs in and keep the stock ones. because i dont want to ripe the head off and put the valve springs in if i can use the stock ones with out them breaking.
thanks
that should’nt be a problem. but i would suggest you put ure valves prings, but if you decide just to put the cams, you will be ok dont worry.
90ls 4dr
what crower cams do you have? If you have the 403 you have to swap the dual spring over. If you get a compession gauge kit you can connect the air line to it and change the valve springs.
i got 403’s and the dual springs but im afraid to drop a valve.
