B20 swap info
i recommend getting a chipped ecu and running a b20 base map… after using the stock ls ecu on my b20 swap i finally got a p06 socketed and chipped with a dyno tuned bolton b20 map and there is quite a noticable difference in power
check this site for everything b20
http://hybrid.honda-perf.org/tech/b20/b20dyno.html
[QUOTE=rayzian;2232692]i recommend getting a chipped ecu and running a b20 base map… after using the stock ls ecu on my b20 swap i finally got a p06 socketed and chipped with a dyno tuned bolton b20 map and there is quite a noticable difference in power
http://hybrid.honda-perf.org/tech/b20/b20dyno.html[/QUOTE]
How much is a chipped ecu with b20 base map. I just finish getting b20z swap using stock ls ecu.
My thread on here has some pictures too. Extension of the fan switch. I had to switch the crank pulley too because the PS belt is different. As far as running/fuel. Seems fine to me.
I kept everything obd0. So far so good. I think my only mods is to get a b16 intake manifold and tb.
