b20 thermostat..is it the same as the B18A1
From what i remember the timeing belt is different. is the thermostat
yes, everything is identical…even the timing belt from b20 to b18 a or b are the same. the gsr b18c is the only diff motor where the timing belt is diff, water pump, intake man etc are diff.
B18c GSR & Type-Rs are the same tooth count.
B16’s are different.
B18a/b and B20 are the same.
So there are three different belts for the different b-series motors.
well put unified:excite:
that would mean the waterpump too. Thanks guys. you are a great help.
