I am swaping a b20 head on a b18a block. What should I torque the head bolts and the cam shaft bearing cap bolts down at? Thanks!
well my '90 shop manual says 61lbs for each head bolt (don’t forget oiling threads and torque sequence). the cam shaft cam bolt are 7lbs after a two step tightening sequence. I’d be surprised if the b20 head needed different torques.
d
