b20 vtec
whats a good b20 vtec biuld ie intake mani block gaurd so forth so on looking to spent less than 1500 on parts i hae the b20 and b16 parts
bang 4 buck i guess would b the ?
what parts do you already have from the b20 and b16? There are a lot of other miniscule things that you will need. Since you are only planning on spending 1500. Those missing things can start cutting away at you pre determined budget even before the build actually starts.
I suggest you go on Honda-Tech. There’s this guy named BAMBAM on there. He has basically done the be all/end all LS/B20 Vtec guides.
http://www.honda-tech.com/showthread.php?t=1676914 Here’s the URL.
You talking about just dropping a stock B20 block with a stock B16 head into your car without rebuilding it, and slapping on I/H/E? Or fully built? Fully built you won’t be able to do for any less than $2k with the proper machining, and even that might be cutting it close.
full b20 and full b16a2 swap
both the moters have around 40k on them
Wait… Are you asking which would be better bang for the buck between B20 and B16? That wasn’t the original question.
they asked what i had thats what i have as of now
If you have both motors. It is really your own preference.
B20 - Torquey
B16 - Vtec unit which is kinda fun.
If it was me… I would most likely swap the b16 into your car and slowly build the b20 block. Once that’s done, swap dowels on the head and expand the circumference of the cumbustion charber of the head as well to accomodate the b20’s bore.
But that’s just me…
how would u biuld it
I am assumming that you are inquiring about the b20 block. I like doing things once the right way.
Again this is only what I would do.
  1. Re-hone the cylinder walls.
  2. Shot peen the connecting rods w/ ARP rod bolts. (I would only use the stock rods if I am staying around the 200 WHP area)
  3. I would use forged pistons. (OEM pistons are Cast. Vtec motors have oil squirters pointed under the piston. This is used to cool the piston while operating @ very high RPMs. Since the B20 doesn’t have oil squirters, the cast pistons might get too hot. I would use Forged b/c they can operate @ the much higher temperature plus you are also adding piece of mind.)
  4. Balance rotating assembly (i.e balancing and micropolishing the crank, and rods.)
  5. I would also use a block girdle. All B series Vtec motors have them. They are there for a reason. Golden Eagle sell them.
  6. Now this step is debatable. Block guard.
  7. Most important of all… Tune it!!!
This is only what I would do. Again read the URL that I left in my first post. That thread has ALOT of useful information.
I would go forged if you were boosting or couldn’t find a piston for your needs. For an all motor app you don’t need to spend half a G on pistons its a waste. RCP engineering make CTR rep pistons (cast) in 84 and 84.5mm for half what a forged piston costs. You get the high comp without getting raped on high comp pistons that will never see more than 220 whp(you’ll need more than 1500 to get there, and lotsa revs, so you’ll have to build the head).
Spend your cash on Hondata if you really want to blow 500, you’ll need it anyway once you start changing cams and pistons and plopping a vtec head on your b20. Get some nice cams (you could start with ITR/CTR cams, I have heard good thinks about skunk for N/A), a nice header (by this I don’t mean greddy megan or DC etc).
For 1500 though I would recommend waiting dependoing on what you want to do with it. You can spend 1500 just rebuilding the bottom end with new bearings, arp hardware and those pistons. A nice replica header can set you back however much you want lol.
I am sorta wanting to sell my turbo kit to build a b20/vtec lol. My buddy and I looked into building it this way and I have a b17 crank so revving the bottom won’t be an issue.
ALso reading the post above mine if you want peace of mind seriously fuck expensive forged pistons with less than 200whp. Peace of mind will come all from the tune. Period. If you want to add to that peace of mind get some arp hardware while putting it together.
^ x2
I would go forged internals for a boosted application looking to push high boost, but for all motor, it’s a waste. Forged pistons can also make your rings wear out more quickly from piston slap during cold start up. Stick with oem, or maybe some RS machines Type R replicas (what I run). Definitely spend the money for a tune. No matter how much you put into the motor, you can never enjoy it if it’s not running properly and to it’s full potential. Look into ectune, and find a good tuner local to you. I can suggest someone if you need.
this is what im thinking tell me what u think shave the head port and polish and block match the head to the block ie combustion chamber, after market intake mani and tb, block gaurd and crank gurdal off the b16. the tune will b taken care of by monster moters in wenston salom nc.
look to spend at least 3 grand to do it right and i would go forged for 2 reasons one is because b20 blocks dont have oil squirters and cast pistons heat up and cause detonation and 2 you get to choose what desired compression you want the cast ctr and itr replica b20 piston only come with one compression option and unless you want around 12:1 compression which i personally dont want but hey if you wanna go that high then they are good for ya a 84mm ctr piston would yield over 13:1 comp with a b16 head and that my friend you really cant run anything under 100 octane fuel although im sure people will say you can and so on and so on but if its a dd its not advised 11.5:1 is more ideal for the street those cast itr replicas are about 300 bucks for a extra 150 you get a better piston and your desired compression so technically you are spending at best 200 bucks more then what you already gonna have to spend i would spend the extra 200 and have assurance
