for those who have done the swap, what trannys are you guys running and what trannys would you recommend and why? when i do the b20 swap i will only have i/h/e and would like to keep the b20 stock, well maybe just cams, would my ls tranny be ok? i have kinda searched but nothing found.
Originally posted by K.C.
[B]for those who have done the swap, what trannys are you guys running and what trannys would you recommend and why? when i do the b20 swap i will only have i/h/e and would like to keep the b20 stock, well maybe just cams, would my ls tranny be ok? i have kinda searched but nothing found.
thanks [/B]
shorter geared tranny will work best, be it ys1, s1, j1, y1
is the first and second gear of a GS-R 92-93 (for example) shorter than the first and second of the 92-93 LS tranny or is the GS-R first and second gear longer than the LS ?
i think that’s it but i’m not sure, that would make the 3-4-5 gear shorter on the GS-R …
