B20b valve adjustment
Are the specs different on the B20b from the stock 91 b18a? What are they? I have everything from my stock B18 swapped to the b20 if that makes any difference.
I’m sure I can google and I will, but I would also like to know what all of you guys have to say as I couldn’t find my answer to this question in the forum.
Found this, but doesn’t seem helpful. http://forums.g2ic.com/showthread.php?52486-B20-Valve-Clearances
From a google search I found someone saying I need to use the b18b specs and not my stock b18a specs.
HELP!! Looking for the concrete answer here (not a “basically the same” answer), maybe someone on Hondatech can get the legit specs?
Intake: 0.003"-0.005"
Exhaust: 0.006"-0.008"
Same as the B18b.
Yeah I found that info too. Just wanted to make sure someone else could verify this before I went off and used the B18a info under my hood.
