back lights won turn on when braking.. helpp!!!
am sorry if i ask to many question… bbut i just gat a fixit ticke an i need to fix my lights… i alredy change the sensor… an still won work… an i change some fueses but still won work… if any body when through this helpp…
I believe there is a ground for the tail lights in the trunk under the lights. Check that its bolted correctly.
MM&Y of car?
What does not work, brake lights, tail lights, rear signals/hazard lights, some or all of the the lights?
Do tail/signal/hazard lights work untill you step on the brake?
Have you checked to see if there is power at the brake light switch, [“sensor”]? 94
