back up lights not working
\\my fuse is good and so is the relay but back up llights dont come on and my ac and heater lights dont come on everything els is fine the dash and tail lights work and that is it any one know whats up
Have you been monkying around under the dash recently or anything?
If so start re-checking anytihng you did…Do you remember the last time they worked? Anything change up till then?
back up lights
I just got the car its a 92 gsr everything was stock and i dont work thats all i know and i checked everything i have another da that i have had for years and never had this problem
The back-up lights are on the same fuse as the signal lights, so if the signal lights work your back-up lights problem is probably at the “A/T Gear Position Switch”, [automatic] or the “Back- Up Lights Switch”, [5 speed].
If the parking lights, [tail lights] and dash lights work and only the HVAC head lights do not work then the problem is at the HVAC head.
Is the problem with the HVAC head lighting the 2 lights above the control shining down or the lights on the buttons themselves?
If it is the illumination lights from above I would check the bulbs, if it is the lights in the buttons then it is probably the “Dimming Circuit” in the HVAC control head itself, it powers the LEDs that illuminate the buttons.:whisper:94
