the rear windshielf spry wont spray any water… and when i try to spray water … i see somewater leaking fron uunderthe car … exactly under front of the driver door
Pull the driverside fender well out, the black part. See if you can see where it’s leaking from the fender. I need to pull my whole hose out because it’s plugged up somewhere. But go from there and follow where the line is going and have a friend use the sprayer
okay thanks ill try that 2 moro… but lets say i pull the hose… and it unplugs from where its spost 2 go to… how would i rewire that hose… last time i hooked up the hood spry it was a bitch 2 do
take off your front bumper it takes 5 min tops. easy access to the wiper resevor. disconnect the rear hose and drain the resevor if its got any thing in it. then take the screw in the middle of the headliner out. take the headliner trim off and slightly pull the headliner down and disconnect the hose form the sprayer. take an air hose and blow it out from the sprayer side first till theres a good amount of air comming out, then reattach the hose to the sprayer and blow air throuh the resevor side and make sure the sprayer isnt clogged. mine was so i stuck a little needle in the sprayer hole and got the gunk out. connect everythign and test. mine worked so good it shot about 10ft straight out. i pointed it to my right so i can spray friends when i park next to them.
