Backfire?
i just want to know what causes backfire? mines just started to do it is there somthing wrong?
The only time I’ve seen one of my tegs backfire was when the distributor bearing was on it’s last ball… I’ve seen DSM’s backfire when their cam angle sensors go bad so check your timing/distributor.
HTH
kool ill try that Ne 1 else know Nething?
Yeah… . ignition timing is the usual culprit. I’d also give the plugs a once over to make sure you’re burning cleanly.
If you are asking what a backfire is, it is unburnt gases igniting in the intake manifold or exhaust. The causes range from electrical(a known problem in our cars) to bad air/fuel mixture.
