Backside fuse panel question
What is the function of this harness on the back of the fuse panel? Where does it go to because for some reason my 90 Teg does not have this cable and i was getting ready to swap out my ICU from another car i took it out of that had a cable hook right there but mine does’nt and i cant seem to find it under the carpet anywhere. I dont know what color the wires are so i cant use my manual to figure it out. The one on the right backside facing the front of the fuse panel is there just not the left. Can anybody help? Thanks
IS it jsut an empty plug socket?
Could be a number of things I’m sure… maybe for a 4dr or something like that, maybe an aftermarket option of some kind. There is a random socket in the back of the vehicle to that is used when towing a trailer of all things.
From a 91 Acura Integra Electrical Troubleshooting Manual the dash fuse box diagram depicts it as C505/hatchback or C555/sedan to rear wiring harness (Canadian models). I believe it is used for power to the hazard switch, shift position console light and back up light switch on Canadian models only, that is if I am reading the diagram properly. I’m not sure how many wires but one would be a YEL/RED wire.
Well my hazards work, the car i took it out of was a manual so its not the shift position console light, and my back up lights work just fine too. So that cable has to have some other function. Thanks. Any other takers?
anybody??
He already told you. It is for those features ONLY on Canadian models.
I am going over to work on my db2 today. If I remember I’ll take a look also though.
You can also get yourself the FSM for free from hondahookup.com which has all wiring diagrams. Just gotta make an account.
I appreciate help. I guess i can put that to rest. Thanks
