bad vibration...
1992 Integra GSR…everything stock (just lowered, Tein STech’s…1.2" lower?)…
k, so last week i desided it was time to replace my axle cuz the inner boot was torn and im getting a clunk from the front end, figure its a good place to start…
the inner cup WONT come out of the intermate shaft, and yes we have tried… so i stole another “SK7” shaft from my buddies house when we couldnt seperate mine. threw that in and slid in my brand new (NOT remaned) axle in. took it for a spin up the block and i get a vibration…
vibration: under heavy load (more than 50% throttle) its just slight, but you get to ~50 to 65mph it vibrates like all hell (like the wheels are gonna fall off…yes they are torqued down proporly) then dissapears… i can cruise at 80mph…umm i mean the speed limit… with no problem, no vibration unless i smash back on the throttle to “pass” the i get a little vibe… also, nailed a hard long right hander under load…big vibration like the wheels were hoppin…
things tried: both sets of my wheels, tighting the intermiate shaft, torquing all the lugnuts, takin out the seal on the end of the axle and using a different axle nut…
:surrend: any more ideas?
My first thought is the engine and transmission mounts. Mine was acting in a similar fashion after my swap. I did it on the cheap with urethane mount inserts and a little bit of liquid urethane to fill in the extra gaps.
