What are the symptoms of a ball joint problem? I was told by someone that my 91 teg could have a ball joint problem.
squeeking is one
Steering play, tire ware, tracking, knocking over un even road surfaces, play in the front wheels when the suspension is unloaded. Generally squeaking is not a sigh of ball joint ware, commonly a symptom of suspension bushing problems.
Put me down for all symptoms! I ordered the lower ball joints and damper fork bushings from Acura last week. Hopefully this will remedy the problem…
there’s also and upper ball joint as well
That’s on the upper control arm right? I saw a camber kit that included ball joints(Ricky Racer). Are those any good, or would a dealer part be a wiser choice?
