n I searched but could not find a definitive answer, not sure if I have a problem or not…
I am changing out my hub bearing and have removed the whole hub to take and get a new bearing pressed in.
When I separated the steering arm ball joint a bit of black grease came out, the rubber boot is in good condition and the joint moves smoothly, is the grease an issue? thinking i should replace the tie rod end…
also the upper ball joint is completely dry, looks like there has never been grease in there at all. I took the boot off and it is in good nick, but it does not seal up the joint at all, is it supposed to? the joint moves freely and smooth and i have not noticed any other problems with the driving of the car aside from the bearing.
I have no experience with what is ‘normal’ here!
There should be grease inside the boots. The boots are held on by spring-like rings. Check to see if the rings are still there, if not, get new rings and if possible, try to squeeze some grease inside the boots before putting on the spring locks.
If the joints are nice and firm and not all wobbly then you are fine… no need to replace. Just grease it good and lock up the boots with new spring locks.
if there’s no loose i wouldn’t worry about it. just adding grease in the boot won’t do much. your joints would have to have grease zerts on them so that grease actually goes into the joint and not only on the outside. you can add some grease on the joint with your finger and in the boot if you want and you should be good.
the upper balljoint on my car doesnt seal either, mine are due to hairline cracks in the boot, theyve been this way for almost 10k miles, no dirt in them or any grinding coming from up front.
i think those joints, being in such a high area, hardly see much dirt being thrown at it enough to penetrate any small holes the boot my have.
