Battery draining
Are you sure it is the rad fan relay that is staying on, [that you can hear click off and on when you disconnect and reconnect the batt.?
If the relay is on the rad fan should also be on.
Unplug the rad fan relay and see if you can still hear a relay click.:hmm:94
ok fcm, I got a new optima and now the car is acting normal again. i don’t know what to say only that maybe when the alternator was going out, the battery was being overworked. Well that’s my guess anywho.
You may be right, it was obviously a batt. problem, but it’s sounds all good now.:up:94
hey well I will be doing this process pretty soon since I also have a draw. I DID notice a relay click sound everytime i disconnected the battery. Not sure which relay it was but I guess it could be a bad relay? I already disconnected a switch that I had installed on my radio (FM Modulator input). I disconnected the stereo, still had a draw.
I want to replace all my grounds, is there a tutorial on here or know where that is located in the helms manual? I also need to know where I can get the parts cheap.
