Hey guys, got my alternator replaced a while ago, and the battery light is flickering at random times while driving, it’ll turn off for a bit and then come back on again. When i’m in neutral or at a complete stop, the battery light will not come on, only when i’m reving in the low to mid range the battery light goes on. Stereo also goes off sometimes when the light is on. I’ve checked for a loose ground wire, but haven’t found any loose connection.
remove the tail light bulbs. see if the DRLs still come on with the brakes applied.
do you know the specs of the alternator? may not be a high enough amperage rating. or, it may just be a cheap alternator that’s over rated.
clean the mating surfaces of the transmission to chassis ground, chassis to battery ground, and both battery terminals. use sandpaper. be sure the surfaces are clean and shiney. also, be sure that the alternator terminal is tight
