Today my battery light came on. Everything felt normal. I was going about 30mph when i noticed it come on. It went off soon. Then later it went back on. I got out of my car and when i got back in and started my car, it was still on. I dove down the road awhile then it turned off…whats wrong? is my car possesed? Please tell me
Your alternator is probably dieing. If the light comes on at low RPMs, and goes off at higher RPMs its a dead give away that your alternator is about to kick the bucket.
-Steve
nope, nothing like that…it comes on at whatever RPM it seems like it wasnt to come on at. I’m so confused. I need to get a multimeter i suppose.
Originally posted by DAY U IZ
[B]Your alternator is probably dieing. If the light comes on at low RPMs, and goes off at higher RPMs its a dead give away that your alternator is about to kick the bucket.
-Steve [/B]
One question…Are the brushes in the alternator replaceable or not???
And my battery light goes off when im past 3k RPM…
Thanx…![]()
could be a loose battery connection too.
When the battery light comes on that means that the alternator is not charging propery.
The brushes are replacable and can be a bit difficult of you have never done it before. replace the srpings also and clean the comm of the alt too.
HTH
also check your alternator belt, see if it’s loose, mine did that too and it turned out to be a loose alternator belt
Gav: The connection is aiight ![]()
teg2nv: Im prolly juss gonna buy a reman…Less hassle for me ![]()
jaylo: The belt is tight…I checked it already:cool: Its tight…
Thanx for all the post guys!!!
