[QUOTE=fcm;2143418]Replacing parts on your car before you know what is wrong is an expensive way to fix your car, eventually you will replace the “broken” part.
I have a question…
When you say, "my battery light is on when the car is off and the light turns off when the car is on. exactly what do you mean?
The “battery light” is supposed to be off when engine is running.
Are you saying the light turns on when you turn the ign. to the off position, [so key is removable] or just off enough so engine stops running, [accessory position]?
If either of the above, I will have to agree with operator207 and suggest the checking of the grounds, the main ones…
Batt. neg.(-), batt. to chassis and chassis to engine.
These grounds should be removed/undone and both contact surfaces cleaned and the reconnected, making sure they are tight.
Remove the batt. and batt. “box” to access the chassis ground point, fallow the ground cable to it’s engine grounding point, should be on a bracket held in place with bolts mounting transaxle to engine.
If that does not work, [can’t hurt to do the grounds on a car that is more then 15 years old] do the same with the main powers…
Batt. pos.(+), batt. to fuse box, batt. to starter and alt. to fuse box and the main fuses, [the ones that are held in place with screws], same way, remove clean and reconnect.
If you have a, [or can borrow or buy] multimeter, you can do a basic check of the batt. and alt. before you spend money on an alt. you may not need.
Hell, even a $2.99 12V test light can be used for a basic test. 94[/QUOTE]
when i say that i mean that when the car is completely off and the key is out and you look at the dash the light is on. then when you start the car it turns off.
i have a multimeter and checking all the ground is a good idea
do know of any good write ups that can step by step me in checking them?
