My negative battery terminal is corroding up really bad every month or so to the point where my car wont crank. I was wondering if any body has had the same problem and what you did to fix it.
buy some new battery terminals
and maybe ground your starter to your battery so it will crank to get you from point a to point b HOPED IT HELPED
Some people clean the terminal real good then after putting the old or new terminal back on, spread some bearing grease all around it. It helps some with the corrosion.
Russ
indeed. new terminals (5 bucks) and clean battery with wire brush, and put vaseline, yes, vaseline on the battery and your new terminals. slide them on and boom goes the dynamite. never have to worry about them again.:whisper:
