I’m having trouble finding plugs for my GSR. Everything I find is just platinum. Any recommendations? What about iridium plugs?
well platinum is normally what everyone uses. forgot the # for them. but i use denso iridiums. use what ever u think is good for the car or what temp. your car needs.
Platinums are NOT worth the money. Run a simple NGK BKR6E-11. If you’re running higher compression, think about a colder plug like the BRK7E-11. Cost about $6 for four plugs and need to be replaced about every 15,000 miles.
What is the difference between the NGK BKR6E-11 and NGK - BCPR6E-11.
Cause Im running the NGK BKR6E-11 in my B17.
I get them from NAPA for like $1.50 each.
The BCPR6E-11 is about 2mm taller (on the top side) than the BKR6E-11. So basically the only difference is that with the BCPR6E-11 your spark plug wire won’t sit all the way down on your valve cover. It will stick up a bit unlike the BRK6E-11 which will allow the spark plug wire to sit like it should. Not a big deal really.
unless **** gets inside there.
Kool thanks for the info! How did you know that BTW? Other than the fact that you are THE G2Guru.![]()
Im glad Im not running some krazy azz plug that is not supposed to be in there, cause I got the # here.![]()
No problem. This information I found out from experience. That and NGK has a break down of the spark plug codes.
