That carpet was nasty! Looks much better now.
I would love to find a 92-93 gs db1 in good shape! Nice pickup!
glad to see you back in a G2 man and a DB nonetheless…maybe we can link up next time i’m in ATL area
[QUOTE=rollinmyda;2313741]That carpet was nasty! Looks much better now.
I would love to find a 92-93 gs db1 in good shape! Nice pickup![/QUOTE]
thanks i jus need to find some mint db1 seats!
yeah bro hit me up when u come to atl area, hows your db?
FINALLY!!! got it back on the road this weekend. working out some kinks in it right now. I think when i get this vibration out of it i’ll be road worthy…right now i’m just wreaking havoc on local roads to and fro work. but i definitely will
Old Vs New
Energy Suspension
Sway Bar Link Kit-- I was going to purchase Red ,but Summit guy told me they tend to squeak.
Front-23mm
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://farm5.staticflickr.com/4363/36900133736_ca8fe6bf64_o.jpg”}[/IMG2]
Rear 16mm
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://farm5.staticflickr.com/4442/37088542755_7befe4d7c2_o.jpg”}[/IMG2]
Here Some Progress Pics Nothing Special…
Got A New Camera TOO!
sway bar links in [IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://farm5.staticflickr.com/4401/37088543175_b1b0748b08_o.jpg”}[/IMG2]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://farm5.staticflickr.com/4390/36947151891_ff9997f020_o.jpg”}[/IMG2]
front sway bar bushings in [IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://farm5.staticflickr.com/4335/37088542925_0b7809a4ef_o.jpg”}[/IMG2]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://farm5.staticflickr.com/4414/37088543125_dbb39b22e3_o.jpg”}[/IMG2]
rear bushings in [IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://farm5.staticflickr.com/4410/36253382154_5047be0997_o.jpg”}[/IMG2]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://farm5.staticflickr.com/4413/37088543305_614b7fd159_o.jpg”}[/IMG2]
Waiting on my ES Front LCA and Upper Control Arm Bushings Too arrive…
Does Anybody know any tricks for removing the bushings in the LCA’s?
When I did mine, I pressed them out. Some you can’t even press out, you have to press the rubber out and use a sawzall to cut the outer ring of the old bushing.
picked up from a junkyard, getting ready too remove abs.
going to order brakes and rotors right now.
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://farm5.staticflickr.com/4387/36692259690_94823398dc_o.jpg”}[/IMG2]
cool, I’m going to try the socket and soak it in pb blaster and a sledge hammer method first. if that doesnt work, ill probably take them to get pressed out.
If you need help fabricating those two extension lines let me know. I made mine easily.
u gotta pic of that b16 header?
its just a stock b16 header no o2 on it.
So I’m getting a cel light code 17 which is the vehicle speed sensor and my s3 light blinks constantly. Anybody know how I should diaginose it since the speed sensor is run by a cable ?
the db looks sick so far your old da was DIRTY! :inlove:
Replace the sensor. If it’s the cable, come get the one off my parts car.
nevermind i was thinking the b16 header was like the type r header
found the culprit of the ticking bomb and replaced with new acl rod bearings.
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://farm5.staticflickr.com/4354/36918336042_54d507ccfa_o.jpg”}[/IMG2]
[QUOTE=laokid;2313209]maybe i can make it look like this again. my old da9 that got totaled. RIP
Wheels aren’t my style, but that was super clean
Yikes that one bearing looks pretty bad! How did the journal on the crank look? Did you have a machine shop check the crank?
