Blinker problem
Howdy
Both left front and right front turn signals work properly, but I notice a problem with the two front side markers. The left front side markers blinks when I move the turn signal stick to the right. And the right front side marker does not blink at all.
had very similar problems, plus my wipers INT & low settings didn’t work. turned out to be my ICU, cheap/easy fix if that is the case.
Where is the ICU? Is it easy to take out?
I have to agree. the front side markers are controled by the ICU.
The ICU is mounted/plugged into the back of the under dash fuse box… http://cgi.ebay.ca/94-97-acura-integra-OEM-indash-fuse-box-w-fuses-etc-/350348394563?pt=Motors_Car_Truck_Parts_Accessories&hash=item5192644043 this is a G3 fuse box the ICU is the white box, will look the same on your G2. 94
yes, ICU is behind the fuse box under the driver side dash.
its just a couple bolts (socket plus extension, might be 10mm size.) once you get the plastic panels off.
kind of a pain in the ass to get to AND unplug everything, and pull the grey icu box off the back… but it all plugs back in only one way from what I remember.
I didn’t even take the fuse panel all the way out, just unplugged the icu from the back blindly and installed the new one the same way.
if i can do it, you can do it.
