First off I HAVE searched around for answers to my problem on here but no luck.
So my problem is obviously that my blinkers are blinking way too fast. However my hazards blink normal (of course on a different wire setup)
I have NOT tried to change all the bulbs because they all light up and work fine. and NONE are out.
I had a random flasher unit installed when I got the car (the blinkers have blinked fast ever since i got the car) so I went to the junkyard and picked up 3 different OEM flashers. Installed them all and none make the blinkers blink normal.
I thought it was a wiring problem because some (yaywho) was there before and the driver side under hood wire harness was all cut and spliced back together with butt connectors :argh: and some wires were not even connected anymore.
So last week I Cut them all out and and cut them all to even lengths and stripped, soldered, and heat shrinked them all.
Still the Problem not fixed. Wires were also cut down towards the lights along with some plugs, but the plugs are no longer there and I have tried to even double ground the blinkers, and still doesnt fix it. and I looked in the under dash fuse box and everything looked okay there. there are some wires that are not connected under the knee pannel on the driver side but from what I can see is that they are coming from the alarm module box. but i have temporarily connected them to see if it fixed anything and it did not
Does anyone have anything else I can try? I am getting frustrated with it -_____-
