Ok So I just bought a 91 integra ls that has a few problems. My first one that ive decided to tackle is the blower for ac and heat not working. The ac has been pulled out as well as the hoses for the heater core. But the fan inside the car will not come on. Any ideas of what the problem could be? I am in the process of getting all the right fuses in the fuse box but i havent found any that were blown. Some were just the wrong size. Thank you in advance for your help
there is a relay thingy right behind the dash mine just got replaced i had the same problem and now it blows like a champ
Is the fan siezed? Our blowers tend to lock up especially if water was getting in there. You should at least have the high settings working if power is present. It doesn’t sound like a blower resistor issue. I would start by getting an Ohmmeter check if you have power. If not, then go for the relay.
i had the same problem where would the relay be???
check the 40a fuse and make sure it’s not broken. You’ll need a screwdriver to get to it.
