Blox Spherical Adjustable endlinks
I had recently purchased these endlinks and I have to tell you I was pretty excited. I go to install the kit and the bolts that are provided are too big. The OEM bolt that goes into the control arm is a 9mm bolt. The bolts that come with the kit are all 10mm bolts. So I was a little disappointed with this. The kit almost does not seem that it is the right one for the car, there is no label on the box. I am going to contact the vender and see what happens.:sad:
I contacted the vender and I was a little disappointed with the response. They told me that I either have to buy the BLOX rear LCA or drill out the 9mm hole on the OEM rear LCA to tap in a 10mm. I am not going to purchase anything from this company again.:frowning:
I thought I saw somewhere that these endlinks are meant to hookup with the Blox LCA’s cuz when you install the Blox LCA’s… the stock sway bar doesn’t hook up withit hence the need for the aftermarket Blox endlinks.
When I installed the Blox LCA’s, I somehow pulled the end of the sway bar down to the mounting hole on the Bloz LCA’s and screw it on with a bolt and locking nut… seems fine to me… but would look much nicer with the endlinks.
So maybe these endlinks are not meant to be used with the stock LCA’s… or am I missing something…
It would be nice if they had stated that in their advertisement. Oh well life is a learning experience, live and learn.
Try contacting Adam from Weksos (one of our vendors on here) and ask him about the Blox endlinks since they provide alot of Blox products… cool guy and will answer your questions accordingly…
And to add to this… I do remember seeing somewhere that it DID state that the endlinks are to be used with the Blox LCA’s. Maybe some sites states it… some don’t shrug :bowthank:
blox products are very good products
I am not knocking the product, I am impressed with the product. I am just a little disappointed that in order for the endlinks to fit I have to modify the control arm.
thats almost with every aftermarket part out there right now. i am glad you like the blox endlinks, i under stand you dont like the idea of it having to be modified, but there is always a good and bad in things.
