Blue/grey smoke = oil?
I have a problem losing oil. It seems like I lose over a quart a month. I changed my oil, filter, and pcv valve(i’ve done the pcv before) and half a month later i’m still over the full mark but I have been driving easy.
Today I had a friend look at my exhaust and reved it up to around 5800. He said it smoked blue/grey and then I smelled the smoke. It smelled like raw oil/ with a little gas smell too. So I’m guessing as long as I don’t rev it up i’ll be fine on oil consumption but it goes fast when it is revved. Is it just blowing by the piston rings? Or is it maybe coming out the valve cover tube and going back into the intake and being burned? I took off my intake tube a while back and the inside of the IM was filled with soot but it wasn’t wet. I figured it was normal for a 13 year old car.
If you want to know exactly where you are losing your oil then you should do a leakdown test. That is the only way to find out for sure.
Later,
BR
