I was driving infront of one of my buddies today, and i was revin pretty high in VTEC and my buddy said that when i gave it at high rpm there was i think he said blue maybe black smoke coming out of the exhaust. Anyone know what this could be?
And my car doesnt really burn oil, After like 4000kms its down to like 3/4 full maybe a little more.
Don’t worry about it man… if after that many K you’re down less than a litre of oil it’s all good. Are you running a catalityc converter? I’ve noticed cars that don’t have them puff more after they are taken off.
You are burning oil I think. Time to check gaskets and seals.
maybe your piston rings are getting bad… just a thot
Have it checked out now rather than later, you’ll probably save a few bucks and some time in the long run.
it jus happens… i noticed it from time to time on my stock b18. same time too… high revs, high speeds… its a bit normal, most likely some of the deposits in the manifolds,chambers, or tops of the pistons jus got hot and burned off and flowed out the exh… i wouldnt worry too much unless it continues to happen at all speeds/revs… IMO
