body/frame swap
can you swap the frame of a 90 teg to a 92 body? a friend of mine bent his frame and i have a spare teg and was wondering if it is possibe to swap the frames out. thanks for any help
unibody.
mmmm… u have to be more specific, because the frame is a unibody and unlike the conventionals theses aren’t 2 rails going from the front all the way to the back, these frames are in sections, and it depends on where the frame got bent you can section this out and it be ok…also if you’re not sure how far is bent, try to get it measure by a bodyshop, and they’ll tell you how far and by how much the damage is…
was the collision on the front or rear???
front passager side by the tire.
Bring it to a frame shop. If its not to bad they can probably pull it out for you for few hundred. Not including putting new parts on.
