Bolt Pattern?
I got some wheels for my 90 teg sedan (4dr) that are 4x100 bolt pattern and they are too big for my car. Any ideas why? Do you think that they are just miss labeled? I thought that 4x100 is the smallest that they make? Thanks.
you kno what…i had a sim;ar problem… i had a lil hoop in the middle of the wheel whic was stoping it from going on…check that
by too small do you mean that they won’t fit on the lug studs? If they are 4x100 and don’t fit the studs properly then… then either the wheels are mislabelled (doesn’t seem very likely if the labels are stamped or cast and not just a sticker), or your car no longer has a 4x100 setup (which also isn’t very likely).
When I put the wheels up to the lugs the holes are wider then the studs.
then they are prolly 4x114 (accord/lude/4lug 240…etc)
I had accord hubs on my first integra… they were put in before I bought it though.
