Borg & Warner Nascar Select Spark plug wires
I am giving a review on Borg & Warner Nascar Select Spark plug wires. They suck… now for the reasons that I have to backup my opinion.
  1. They don’t seal to the valve cover good so dust and debris gets into spark plug wells.
  2. The wires will not slide easily in the boot, so if you pull it up too far, you will not be able to push it back down further
  3. They are ugly gray in color (of course not affecting performance, but they could have added a little color)
  4. The boot is an ackward square shape and doesn’t slide down spark plug well smoothly
  5. They have a tendency to pop off spark plug
Don’t buy these. But if you did, return them. These fine paper weights can be bought from Pep Boys, but that could be part of the problem…
6.) They use the word NASCAR in their name.
Re: Borg & Warner Nascar Select Spark plug wires
Originally posted by Shaun Ladd
[B]I am giving a review on Borg & Warner Nascar Select Spark plug wires. They suck… now for the reasons that I have to backup my opinion.
Don’t buy these. But if you did, return them. These fine paper weights can be bought from Pep Boys, but that could be part of the problem… [/B]
I thought i was the only person that had the same problem with those piece of sh*t wires from brog & warner.
B18A93
G2IC
THEY SUCK!!! S-U-C-K… besides that, anyone want to buy a set of NEW Borg & Warner Plug wires…
this is old, but are they reallly that bad. i bought them already. i guess ill install them and see for myself.
