both power windows dont work
my windows were working fine but all of a sudden both of my windows stopped working when i press the button nothing happens at all…I checked all the fuses and they are all fine…any help would be appreciated
myself, i would pop off the door panels and check to see if power is goin to the motor. if you get power to the motor the n more than likely is a bad motor. supply 12v to the motors and see if they operate. check power at the switch. if your not gettin power at the connectors to either the motor or the switches then there might be a wiring issue. this is a educated guess from me. i would have to see wiring diagram first:read:. goodluck!!!
thanks man for the help my passenger side switch i replaced it but what i dont understand is that both of them stopped working at once
like i said without seeing a manual its hard to tell if they sure a circuit. i doubt it. thats basic electric 101. its all process of elimination!
yup i hear ya man just gotta sit down and do it ahha
still haven’t figured out how this happened to me, but the connector leading to the master door switch got disconnected. Still had power going to the fuses and relay but nothing to the switches… Hopefully your problem is as simple as this.
thanks man that is what I have noticed that if the master switch doesnt work both the switches wont work either so lets see
